04-28-2024 10:14 AM
04-28-2024 10:29 AM - edited 04-28-2024 10:30 AM
CSAs don't work overnight, so hopefully will respond in the next several hours. The wait times have been longer than usual.. Does texting work? Do see the US roaming add on in your self service account?
I will also suggest a simple reboot of your phone. Network reset of the phone (this will erase any saved Wifi passwords)
Might want to manually select LTE/4G network instead of 5G (or Auto).
Here is some addiontal information:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
04-28-2024 10:20 AM
@Sumandeep - Please enable data roaming as US networks are not built by TELUS / Public Mobile / Bell.
Use:
And for calls, you will need a specific device for VoLTE as your device may not be compatible. Please check the help article for info.
https://publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
https://publicmobile.ca/en/ab/get-help/articles/volte
Also have you bought the correct add-on? In My Account, does it show up?
