11-22-2024 03:57 PM
Is this possible with PM?..I've changed access point setting and send in MMS,.just wondering if this can be done ?
11-22-2024 10:29 PM
@hTideGnow wrote:hi @will13am
some people on OnePlus mention about the all caps requirements too
This speaks to why OnePlus is no longer the brand that it once was. It is not something I would want to buy these days.
11-22-2024 10:11 PM
hi @will13am
11-22-2024 10:05 PM
This is strange. I have never entered APN in caps before for manual entries and I have never seen APNs in the configuration file use caps. It is sort of like website URL. Whatever works.
11-22-2024 09:56 PM
I had to capitalize SP.MB.COM in my APN settings to send pics between 2 phones
Hope this helps someone
11-22-2024 04:55 PM
To use rcs the iPhone need to be updated to the latest ios 18 for better quality pictures. But you can still send pictures the old way as well.
11-22-2024 04:15 PM
Ok thanks
11-22-2024 03:59 PM
HI @Lloyd4
yes. You can send regular MMS to iPhone or if your iPhone friends has RCS enabled and setup correctly, you can send the pictures using RCS to them
11-22-2024 03:58 PM
it's a phone settings, not PM. You can definitely send MMS to iPhone
