08-08-2017 06:56 PM - edited 01-04-2022 02:27 PM
Anyone having issue when Wifi hotspot is enabled, others devices connected has no internet connection? Devices can connect fine however can't access the internet,it was always working but not today?
07-16-2019 06:35 AM
I had the same problem. It was on a phone that runs on an old version of Android (KitKat 4.2). I use the phone as my Wifi-hotspot. When the conectivity problem occured, the phone would allow other devices to connect via Wi-Fi. However, connected devices could not pages on a broswer. I was bummed about this and could not figure out what the problem was. My data connection was on. The issue was not the Internet service provider either because I could share Internet via USB teethering and it would work just fine.
Anyway, I noticed that the problem was due to Wi-Fi throttling. Diable/uncheck this option and viola! Wi-Fi hotspot works perfectly as before. The setting in my case is found in wi-fi hotspot settings >> Bandwidth Usage, Keep in mind that access to the mentioned setting may differ depending on your Android version.
10-05-2018 03:01 PM
I also previously had an issue with the iPhone Hotspot. I can confirm Settings > Cellular > Cellular Data Network > APN sp.mb.com fixed my hotspot issue on iOS 12. Hopefully this will help others that has the same problem as me.
08-15-2018 11:53 AM
@Oszkari please keep us posted 🙂
08-15-2018 01:04 AM
Thanks for the reply! I can turn on the hotspot, the client (ipad) can connect to the wifi hotspot but the internet will not work.
I will try to reach out to a moderator as you suggested.
08-10-2018 03:11 PM
@Oszkari out of curiosity, what happens when you try to use it? Are you unable to turn the hotspot on on your phone? Are you unable to connect a client device? Are you able to enable, and connect, but the client device reports no internet available?
You may want to reach out to the moderator team to check your account for any provisioning errors that may lead to this situation:
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
How can I view my private messages between myself and a Community Moderator?
08-10-2018 02:13 PM
Hi,
I have recently moved an android phone from Telus to PM. Eversince then the wifi hotspot stopped working. Internet is working just fine on the phone using the recommdended APN settings however sharing does not.
Some people on the forum had success by adding the dun apn type, but not me.
Im running 4.4 android. Any idea what else i can try?
thanks!
01-20-2018 03:51 AM
Is it work with https://mobile-phone-tracker.org/ mobile recorder on Android?
08-12-2017 12:59 AM
@Alexo wrote:i got a call from a Telus tech.
The problem has been confirmed to be a misconfigured rule in their system, and is supposed to have been fixed by now.
I have tested tethering and it works right now, so if you still have a problem, it should be due to something else.
Confirmed, working back to normal - at least for now.
08-11-2017 06:48 PM
08-11-2017 06:14 PM
Just tested it. Everything is as it should. 4 days of frustration as to what was wrong. At the cottage all week. I do rely on my hotspot
Glad its fixed.
Thx to all who got things going!
08-11-2017 05:55 PM
One question remains: why did it take 4 working days to diagnose and fix?
08-11-2017 03:27 PM
Thank you Dear,
Already I did.
08-11-2017 03:13 PM
08-11-2017 01:45 PM
08-11-2017 10:17 AM
08-11-2017 03:58 AM
08-11-2017 01:41 AM
08-11-2017 12:14 AM
@logikol wrote:Hi all,
Just want to provide an update. Although it shows that "internet access" is established on my computer when tethering from my iPhone 6 Plus, websites/chat/internet traffic is not going through.
INTERESTINGLY, however, I am able to log into the publicmobile self service site and access my account and details (though, painfully slow). No other site is working. I have tried restarting the phone, turning off data then restarting and turning it back on, resetting network settings, deleting all profiles, connecting via wifi/usb/bluetooth all to no avail....this was across two different devices and PM sim cards.
@CS_Agent PLEASE HELP!
Tethering via my Pixel is broken since Tuesday as well. I can confirm that only publicmobile.ca is allowed, everything else is blocked.
Adding "dun" to APN type list did not work for me. My phone is already on sp.mb.com. I've tested tethering via bloutooth and wifi, both are broken. @CS_Agent please fix it on your end or provide a solution.
08-10-2017 10:03 PM
08-10-2017 10:00 PM
Hi
yes it is a global problem and I thinke they will not fix it soon -- looks to me
08-10-2017 09:58 PM
08-10-2017 09:54 PM
I got a call from a PM rep and his solution worked on my iPhone!
Go to Settings, Cellular, Cellular Data Options, Cellular Data Network
and change it from isp.mb.com to sp.mb.com
That's it! No restart required. I just did this on my phone and it worked! Give it a shot!
08-10-2017 06:34 PM
08-10-2017 04:49 PM
Thanks @computergeek541! I was having this problem still with my "test" 3G SIM in an old phone, but adding dun to the APN resolved it. Great work!
08-10-2017 01:36 AM - edited 08-10-2017 06:47 PM
Ok, I've managed to get tethering to work. The solution (as talked about earlier) is to add the access point type of dun to the APN sb.mb.com. This is a pain because my phone greys everything out and doensn't allow any changes, and you have to create a new access point. This is a workaround, but it still doesn't explain why the isp.mb.com for dun no longer works.
I have also figured out that if your phone doesn't allow changes to the pre-existing APN, you can just create a second APN for sp.mb.com with APN type of dun, but you don't need to input the rest of the settings. The phone will succesfully use both APN entries for sp.mb.com in combination. Now, if your phone doensn't grey out the ability to edit the existing access point, you can just add the dun settting to APN type.
Making a long story short: There is still something wrong on the Public Mobile end. isp.mb.com has stopped working for dun (tethering). Adding the APN type of dun to sp.mb.com (or creating a second APN entry of sp.mb.com with APN type of dun) should get you up and running.
08-10-2017 01:17 AM
Some thing is still messed up on the Public Mobile end. This isn't a phone issue, at least in my case. Tethering used to work but it has just stopped. Nothing has changed on my end. The connection looks fine to the tethered device (my laptop) and it shows as having a valid internet connection but no traffic comes through.
08-09-2017 09:52 PM
@logikol, are you able to swap sims with your brother? This would be a good test. 🙂
08-09-2017 07:56 PM - edited 08-09-2017 08:13 PM
Hi all,
ALSO INTERESTINGLY, my brother who lives 20 minutes away from me who is also using PM has no issues with tethering on his Nexus 6P.
08-09-2017 07:41 PM
08-09-2017 06:46 PM
