07-13-2024 05:50 PM
Hello
I have an American data and text plan on my account. I am connected to at and t but my text and data do not work. Any ideas?
07-13-2024 05:57 PM
Hi @Eric37
First, go into your settings. Find Network Settings. Make sure your data roaming is turned on. Then under Network Settings, turn off automatic. Then choose T-Mobile. Then Reboot the phone. You should be up and running.
07-13-2024 05:56 PM
try manual connect to T-Mobile as well
use 4G or LTE and not 5G
you can also try Verizon
07-13-2024 05:52 PM
@Eric37 Two things to try. If you are on 5G, drop to 4G/LTE especially if on AT&T. If that doesn't work or is not applicable, try T-Mobile.
