Alternate phone number in the my plan section
zblackma
Has anyone ever got a call from PM? I'm curious since looking at some of the problems posted here, I would think they would have. Thanks.
zblackma
Thankyou. Appreciate that you took the time to reply. Will accept this as my solution.
@popping wrote:
Your alternate phone number is used to verify that you are the owner of your account if you forgot your PIN#.
Don't know your pin?--provide any 3 of the following:
- Complete mailing address,
- Email address,
- Alternate phone number,
- Date of birth,
- Last top up date & amount
@zblackma  @popping  is correct that it can also be used as an identifier for verification purposes. The escalations department of public mobile will call customers to settle disputes or leave a number for the customer to call that department.
popping
- Email address,
- Date of birth,
Staliger
No calls, only text messages.
iliusfaisal
I never heard of getting call from them
kselmak
I only heard about the problems with the port. People did receive calls from  pm/Telus employees if information was insufficient or something was wrong. I never heard of any other call which doesn't mean it didn't happen, so I would still keep the correct alternative number. If you don't have any I recommend fongo.
