02-04-2020 11:29 PM - edited 01-05-2022 09:21 AM
I've recently signed up for PM's $25/mo prepaid plan with 500mb of data.
the phone i'm using is an Alcatel Go Flip 4044V.
when I try to go to a website (any website) is says:
"Server not found. Can't find the server at ... [insert web address]"
the weird thing is, when i use the email app on the phone, it is able to connect to the internet and update with new emails. so just seems to be the "browser" function/app that doesn't connect to the internet.
more info:
JUST NO DATA!
any help would be greatly appreciated!
01-13-2021 10:51 PM
The Alcatel Go Flip 3 is now searching for available updates.
01-13-2021 08:29 PM
02-05-2020 11:53 AM
I have an Alcatel 4044v and I find the browser will crash if you visit a heavy website. Sometimes I will click the top left key fast and enter a simple website before the heavy one finishes loading. Could be a simple search engine or weather site. I find sometimes you have to click on the browser twice to get it out of the crash state. I find it's battery lasts a long time on standby for road trips.
02-05-2020 06:19 AM
@SGJM the phone was never really designed for browsing internet, other than to check your email. It's got a 2 inch screen, no touch capability etc. You would need a magnifying glass to read everthing. Are you trying to get your mother to upgrade to a smartphone ?
02-05-2020 03:15 AM
@SGJM I've never really tried to get the browser to work on my flip phone but I do remember getting a really cute Google page so it is definitely possible. I'll have to look at the settings to see if there's anything that can help you.....the roommate is borrowing it for now. But I'll check in to see if you haven't had any success.
02-05-2020 01:50 AM
I am not the OP asking the question. My mother uses her GO Flip for over 1 year with the PM $10 50/50 plan.
02-05-2020 01:33 AM
@popping true enough, but, if you do the search check, it doesn't show up.
Try it out first to see what I mean. I wouldn't want the moderators giving you the same answer if they check to see if your phone doesn't work.
It could be your phone port is stuck. You may need the moderators here to help
If you do need Moderator assistance, what information should you provide?
Once the Community Moderator has responded to your private message, they will provide you with a secure link so they can authenticate your account information In order to validate your account information, you will be asked for 1) Your account number and 2) Your PIN number
But, wait for them to contact you. Don't post that information on this forum.
02-05-2020 01:22 AM
I purchased my Alcatel Go Flip from TMS. It is a Virgin prepaid phone without getting a Virgin prepaid plan. This is how I know it will work with PM.
BTW, Koodo Alcatel Go Flip was more expensive at that time.
02-05-2020 01:06 AM - edited 02-05-2020 01:06 AM
@popping, @SGJM Did you check to see if your mom's phone is actually able to work on a Public Mobile network?
I looked for the Alcatel Go Flip and Alcatel Go Flip 4044V and I didn't see this model in the drop-down menu. They did have a Go Play phone.
02-05-2020 12:03 AM
My mother is using an Alcatel Go Flip. I cannot remember what I did. I was able to send a picuture MMS to her phone as wall paper. I did not test the browser. It was painful to setup APN with that dial pad.
02-04-2020 11:32 PM - edited 02-04-2020 11:33 PM
Does MMS picture texts work?
Have you tried resetting your network settings?
Can you post a screenshot of your APN settings??
Log into your account do you see any data under my data and add-on section?
They should be like below.
