2 hours ago
Hi, just onboarded to PB a couple of hours ago, when I try to access the app or my account through the browser I'm confronted with "Confirm your identity" and the 6 digit OTP code that's supposed to be sent but it never sends anything. I know my txt is working because i can msg anyone else and receive txts - Otherwise I can txt, call, browse just fine... Any help would be apprecaited it.
31m ago
hi @huko600rr
always happy to help 🙂
32m ago
All of a sudden, everything seems to be working and I finally got a bunch txt msgs! Thanks for your help @hTideGnow
46m ago
Thanks for the help Maire - I have to say it's been a pretty horrible first impression with Public Mobile so far, I just got onto the network hoping for the best, my account is locked up as the OTP is never sent to my phone, when I got in touch with the support, the 2nd one stepped in because the first one left for the day. And now I just discovered that I don't have any Data either! I was browing all this time on my wifi (I took the advertised $30 20GB plan), I've been given an IT reference number and told to wait upto 72 hours sigh...
2 hours ago
hi @huko600rr no, you don't need My Account to check messages. After you sent them message, check their replies here
usually they reply within 4 hours
2 hours ago
Thanks for the link I've emailed them. But in order to check their message don't I need to access my account? I can't do that because of the above issue..
2 hours ago
hi @huko600rr
you need support agent to help. please message them here
