2 hours ago
Hi, my data stops working randomly and this happens multiple times a week. I would have to restart my phone or turn it on airplane mode but sometimes it does not solve it. Also I've been having calls drop issues.
an hour ago
I guess if it works for people great, what I mentioned was just what we experienced at my workplace, perhaps the batch that we got (100+) had some kind manufacturing defects.
an hour ago
HI @huko600rr
actually, A53 is one of the best mid-range phone. Of course you cannot compare with top of the line S2x series, but A53 is the best with that level of phones
and if you check around, people are upset Samsung Canada not bringing back A54 into Canada
an hour ago
Sorry to say the A53 is a HORRIBLE phone, we have deployed this at our workplace and literally every person who got this phone showed how terrible it was constant dropped calls, robotic voice quality, just horrible all around. We are now completely redoing our contract with Rogers and they're giving us $400 credit towards all staff phones
2 hours ago
@nancyp604 wrote:I have Samsung A53
HI @nancyp604
A53 should have no problem using the PM network.
not sure if it is a local network issue. Please ask PM support agent to check.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 hours ago
I'll create a ticket. Thank you.
2 hours ago
I have Samsung A53
2 hours ago
Hi @nancyp604
I'd suggest going into your network settings and reset them all then reboot your phone. If the problem continues, try your SIM card in a different phone if you can to see if the problem is still happening. If not, then you know it's the phone. If it is, then you know it's PM. Then you can create a ticket and ask PM to reset your network on their end.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
2 hours ago
HI @nancyp604
what phone do you have? Try Reset All Networks once and see if it helps
