Agents
lorenzo1961
Are there any agents working right now? I've been try to reconnect with an agent for over 30 minutes and I'm being ignored so far.
10 REPLIES 10
lorenzo1961
Issue has been solved with a new sim card. Thanks for all the messages and replies.
@lorenzo1961
If porting is the issue, there is a number you can call to the Porting Department.
I will pm you their number. They are working now.
Hollister
@lorenzo1961
Can you confirm that your payment went through with the original activation ? If yes, put your original SIM card back in and reboot?
lorenzo1961
I find it alarming that I tried to activate my new service a couple of hours and the sim card wouldn't work so I was told I had to go buy a new sim card which I did...I get back and get no response from anyone?
golfball
You're going to need a lot more patience. They sometimes will not respond for hours or until another day.
Sadly this is what happens when PM sends customer service to the other side of the world and not keep it here in Canada. They will eventually reply to you.
BTW, what issues are you having? Maybe we may have an idea or two?
Hollister
@lorenzo1961
What is your issue? Maybe the community can assist you?
lorenzo1961
It's been 40+ minutes already
Hollister
@lorenzo1961
During business hours, they strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 9 AM to 10 PM EST
Chalupa_Batman
Hey @lorenzo1961
There are CS Agents working now. Just hold tight. If you don't hear from them in an hour, then go to your sent folder and ask for an update. It's 7am there right now. 5pm Cent now for me.
