08-15-2016 11:01 PM - edited 01-04-2022 03:02 PM
08-15-2016 11:54 PM
Just as Jak has replied, you need to select a plan with local calls.
08-15-2016 11:22 PM
08-15-2016 11:19 PM
@Abdou91 wrote:
But i paid 8 dollars for that ! Can they refund !
Not sure. PM staff member will get in touch with you tomorrow and see what they can do.
08-15-2016 11:12 PM
08-15-2016 11:09 PM - edited 08-15-2016 11:19 PM
Hi @Abdou91;
If I understand correctly, you selected a data only plan and then bought a 200 min LD add on planning to make calls with that. Unfortunately, that won't work, the rules are that you need a base talk plan in order to use add on minutes. It's part of fine print bullet #5 on the Plans page " Long distance add-ons require a monthly talk feature on the rate plan."
Unfortunately you are not the first to have run into this, it's pretty common actually, see http://productioncommunity.publicmobile.ca/t5/Public-Lab/Should-block-buying-LD-add-on-if-not-on-a-t...
In the past the moderators have sometimes been able to help out, @Shazia_K @Mary_M
08-15-2016 11:09 PM
As stated above, talk in your plan is required to to use add-on.
08-15-2016 11:07 PM
Unfortunately, you can't use the LD add-on to replace a talk plan. You need a talk plan first.
