06-01-2023 10:30 AM
If you are having trouble after buying data OR you have data that was given as a gift by Public Mobile and have trouble accessing it - check your setting for data limit. My Android phone have setting for 1 GB as that is what is on my plan. I used all of it and had more data available, gave up trying to use it so bought more data, still could not access. My husband who is still grinning like a cat in 2 minutes changed the data limit setting and VOILA I had more data. We are visiting family and in remote location so of course something happened and I needed to send my sympathies in an email to be read at funeral during this time, super stressful. THIS info needs to be on main Public Mobile site. Lots of info to buy data but not a helpful hints page on what could be wrong when you cannot access your data. WORST was getting badges and bravo for posting lots. BUT I was ranting about not getting help, not wanting a badge. Happier Minne Mouse
06-01-2023 10:33 AM
when in doubt, come to the PM Community Forum for tips and suggestions.
Sounds like hubby should be an active Community Forum participant.
06-01-2023 10:32 AM
@MinnieMouse You can check it like this
simply try refreshing the page when logged in
Check add-ons /mins /Data
06-01-2023 10:31 AM
good tips and thanks
Yes, it is a good settings on Android, too bad iOS does not have it (i wish they do 😞 )
but problem with the setting is that it is monthly, PM is 30 days, so , if you are using it, make sure you change the cycle date
