Adding Another number to my account
11-28-2017 08:40 AM - edited 01-05-2022 03:38 AM
I would like to add another number to my account.
Is it possible to have 2 sim cards associated with the same account?
Payment
11-28-2017 01:51 PM
@mimmo it's not for me, doing a solid for someone. 🙂
11-28-2017 01:47 PM
11-28-2017 01:44 PM
@mimmo cool, good to know! I guess the important bit is if you're using the "+", always use it to append something to your username.
Case in point: I tried doing something similar to "na+me@gmail.com" last friday night when activating placing a Koodo order online and let's say it didn't end well for me. After over an hour on hold Saturday morning, I finally got it sorted out, but suffice it to say that while name+something@gmail.com will get to name@gmail.com's inbox, as will na.me@gmail.com, na+me@gmail.com will be delivered to na@gmail.com instead. Probably not the intended result!
11-28-2017 12:54 PM
@srlawren the plus does work with PM ( have used it several times). It can be easier to remember than where you put the "." Ie name+mom@gmail or name+1237@gmail.com ( last digits of number)
That is why I did not mention it.
Great advice re the cc.
11-28-2017 12:09 PM
@bacardi @mimmo not all systems recognize the "+" as a valid character in an email address. I'd suggest you instead use the "." trick, which is slightly different. You can't add in extra suff (like "account2" in your example), but all of these email addresses are considered the same by gmail and will route to name@gmail.com's inbox:
name@gmail.com
n.ame@gmail.com
na.me@gmail.com
nam.e@gmail.com
n.a.me@gmial.com
n.am.e@gmail.com
na.m.e@gmail.com
Do note that many users have experienced an issue trying to add the same credit card to more than TWO public mobile accounts. Some have had success, but many have issues. So if you need more than 2 total lines, I'd suggest you use multiple credit cards (max 2 per card) for the payments.
11-28-2017 10:14 AM
as mentioned above no you can't but if you use gmail you can create an email alias.
name@gmail.com and name+account2@gmail.com are considered the same thing by gmail.
11-28-2017 08:47 AM
@bacardi wrote:I would like to add another number to my account.
No. You will have to have two separate accounts. You will also need two different email addresses to set-up the two accounts. But you can still use the same credit card number.
