04-08-2022
02:14 PM
04-08-2022
03:28 PM
computergeek541
Hello,
Is it possible to add a second phone number to my existing account? I realize the charge would double, but I don't want the additional hassle of creating a second account and separate payments. Would prefer to combine all in one if possible. Thanks in advance for any guidance provided
04-08-2022 04:52 PM
Thank you everyone for the quick response and guidance. Email alias it will be
04-08-2022 03:38 PM
I agree with you, would be Ku h easier but more efficient, but unfortunately they haven't given us that option yet
04-08-2022 03:37 PM
@Thorbr Just add to @dabr note about alias. Not all email servers allow that , but one work for sure is Gmail
Some alias example:
original :johndoe@gmail.com
valid alias:
johndoe+PublicMobile@gmail.com
04-08-2022 03:10 PM
@Thorbr I'd definitely recommend using the email alias as an option, that way all your emails for the second account will come to your main email address, especially if you're going to be the one managing the secondary account. You can also use the same CC for payments and same login password for the self serve account as long as the email is different/alias.
04-08-2022 02:26 PM
HI @Thorbr No possible. One email address one account.
Some people will ask you to use email alias as workaround. But making new email is so easy, I suggest to just get a new Gmail and use that for your second account
04-08-2022 02:20 PM
No. Only one account.
