Add to my plan
jessecriss
I want to upgrade my plan to include 9GB at 4G but just started a new 90 days. I understand I need to pay more but is it the diffence of $15 (current plan is $150) or a whole new $165??? I'm confused.
Jesse
2 REPLIES 2
Lg85
@jessecriss
I think you can send the moderator team a private message as indicated by @NDesai above. They will change the plan for you since you just renewed it. I believe you will probably need to pay the difference to upgrade to the new plan if it costs more than your current one.
NDesai
@jessecriss PM is a pre-paid service and that mean you pay upfront. Since its only been a day, they might be able to switch you to new plan without paying the total amount. Send a private message to the Moderator_Team with your account info and an explanation. Hopefully they can switch you to the new plan.
