11-18-2021 03:47 AM - edited 01-06-2022 04:02 AM
I new to public mobile and I just purchased 20 add ons how am I gonna use my data
11-18-2021 01:13 PM - edited 11-18-2021 01:14 PM
@Sam_Tatatoapik : Let us know what came of your intentions.
11-18-2021 01:07 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
11-18-2021 06:20 AM
@Sam_Tatatoapik wrote:I new to public mobile and I just purchased 20 add ons how am I gonna use my data
I made the same mistake on my phone the other day and got my money back after 30 minutes from CS.
But, if like @esjliv mentioned, you see the $20 still in your Available funds, you don't even have to contact them. Just go back to the add-ons page to buy the correct add-on, the money will be taken from your balance.
11-18-2021 06:06 AM
If you still see the $20 in your Available Funds area then you really did not add the addon to your account yet.
These funds can be used to purchase the correct addon.
Go back to the addon section and select the one you want.
If you do see the addon listed under your Overview section and you have no use for it, then you could see if the CSA's can reverse that for you and put those funds back onto your Available Funds area to be put to use for you.
Contact CSA by either 2 ways, found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-a-moderator
11-18-2021 05:09 AM
No worries. We all make mistakes. If you submit your support ticket now you will probably have a reply in a couple of hours when the CSA's start their day. Welcome to public mobile!
11-18-2021 05:05 AM
Thank you
11-18-2021 04:52 AM
That's ok. It's an honest mistake. Contact customer support and explain that you accidently purchased the US roaming data add on instead of the $15/1gb data add on. The CSA will credit your account. If you can wait til morning then the CSA will also add the correct data add on for you.
If you can't wait then add enough funds to your account to purchase the $15/1gb data add on and select it and confirm and submit your purchase. The $20 credit can be used to pay for your plan on your next renewal.
Click on the chat bubble at the bottom right corner of your screen and type "account related issue" and "human" and follow the prompts to submit your ticket via Simple--Simon. Keep an eye on the envelope icon at the top right corner of your screen next to your avatar for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times.
11-18-2021 04:17 AM
@Sam_Tatatoapik If you bought a $20 data add-on, you can't use it in Canada. That's only for the U.S. The data add-ons for Canada are $5 or $15.
11-18-2021 04:03 AM
11-18-2021 03:52 AM - edited 11-18-2021 03:53 AM
@Sam_Tatatoapik Are you in U.S.? There's no $20 add-on to use in Canada.
