Add ons
Shastadaisy
Hi, I have a $25.00 plan, this doesn't include US calls, and I need to participate in a US call on Aug 31st. I am not sure which add on to choose. Would it be the $8.00 US talk only selection?
@Shastadaisy  if you just need to call US, get the 1000 US min for $15
or, you can call for free if you use VoIP app.  One good one is to use TextNow
@Shastadaisy
Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
Overview Of Add-Ons visit Here link.
hairbag1
@Shastadaisy....
In Canada Long Distance Add-Ons6
Any unused minutes will roll over to your next cycle.
1000 U.S. Long Distance Minutes⁴....$15
 @Shastadaisy : You would want the 1000 minute US calling. It isn't roaming to call the US.
Edit: The $15 add-on for in Canada.
Add money first and then buy the add-on. It seems like you're buying the add-on but you're only adding money. So think of it as simply adding money first.
