10-13-2024 10:27 AM
- I’m currently in the us and am using an esim for data however I’m not able to use my phone to make local calls. If I purchase the US $15 plan from my account will I then be able to make calls?
Add-Ons
10-13-2024 11:28 AM
Try rebooting your phone and see if that helped. Plus as others have recommended to connect to one of the US network and enable VoLTE on your phone.
10-13-2024 11:17 AM
hi @Ross8 what phone do you have? if your phone is not on PM's VoLTE whitelist, voice might not work
A workaround is to use VoIP app like TextNow to make voice calls using the app
10-13-2024 10:37 AM - edited 10-13-2024 10:38 AM
@Ross8, try manually connecting to T-Mobile, and if that still doesn't work try changing your network band to 2G. The issue is very likely that your phone is not on PM's whitelist of VoLTE devices. Do not buy an add-on as that will not help
*edit* I forgot to ask if you have one of the Canada/US plans? If so they above applies. If you do not have a Canada/US plan then you would need a roaming add-on
