12-03-2023 01:52 PM
We are in the US and our talk add-on has expired. Public mobile system will not activate a new add-on. It has been 24 hours if that matters. Is the answer just to get a local simm card? Thanks
12-03-2023 02:06 PM
I appreciate and understand that. I'm just sharing options.
12-03-2023 02:03 PM
hi @Chalupa_Batman but Airalo does not give you Talk/voice call which OP needs, he got Talk addon originally
12-03-2023 02:01 PM
If that option doesn't work, here's another. https://www.airalo.com/united-states-esim you can download a VOIP program like TextNow and pick a local number to where you live and you can use it like a regular phone and text people back home in Canada and to anywhere in the US.
12-03-2023 01:54 PM
hi @Grant-m usually it would be ok to wait 24 hours. So, does new addon appears on My Account?
If it is, try reboot phone
If same, please submit a ticket with CS Agent here:
12-03-2023 01:53 PM
@Grant-m If you have already waiting 24 hours after the first one ends you should be able to rebuy same add on or have to choose another one . However support should be able to apply it for you back to back
you can send a private message To CS_Agents
