Add-on
Gary66
Purchased additional US data; payment was accepted however never received data
9 REPLIES 9
Gary66
Was unable to respond due to not having data, driving across the USA and barely being able to access the community even with Wi-Fi when we did stop. So yes, water under the bridge now.
Glad you got it sorted. We could maybe have been able to help you or other ideas or try to explain it if you had answered all the questions. But water under the bridge now.
Gary66
Not a full rebuy, just needed extra data, had enough roaming from original purchase.
HI @Gary66
thanks for reporting back and glad at least you got your money back
and was that problematic purchase a rebuy,?
Gary66
Never received the add-on when needed during my travels. As an FYI-every suggestion made had been tried prior to posting on the board. Upon return to Canada, was able to contact support and purchase was refunded. The reason the add-on was not active was never addressed nor explained.
This issue could have been resolved immediately had an actual agent been available as this AI chat bot was useless.
Thanks to everyone who suggested possible solutions however none worked.
Hi @Gary66
if you are rebuying same US data, you either have to wait 24 hours or you need to submit a ticket for PM agent to help buying for you.   You can submit ticket here:
@Gary66 you cannot use the US  data or you do not see US data showing up on My Account?
If you just not see the US data showing up, please login My Account once more, but use Incognito mode.  Also, check the Payment history and see if PM took the money and used it for the purchase
https://myaccount.publicmobile.ca/en/account/payment/payment-history
update:
Additional US data, when was the last US data expired? has it been over 24 hours?
If you cannot use the US Data, Critical part to US roaming depends on T-Mobile coverage and whether you can connect to T-Mobile network or not
If the phone is not connecting to T-Mobile, change the Network Connection from Automatic to Manual and select T-Mobile
If your issue is with data, make sure your Roaming Mobile data is enabled and your have disabled your mobile data limter
dust2dust
Which data bucket did you have before? Does it still show in your list of add-ons? Is it at 0/15 days? Which one did you try to buy? Is the amount you paid in your balance? You can either wait for that 0/15 to disappear or ask support to re-buy it for you.
Yummy
Did you try: using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Did your card get charged?
