Add on unlimited text
06-21-2018 07:55 PM - edited 01-04-2022 06:15 PM
06-21-2018 10:17 PM - edited 06-21-2018 10:18 PM
@TeresaHawkins wrote:I even went back to walmart to check and they confirmed that there was a $5 add on to upgrade to unlimited text. I will have to go back again and ask them.
If you click on Plans at the top and then scroll down to Add-Ons, you will see a list of them. Unfortunately, there is no text add-on. But there is a data add-on you can use with a texting app to send more text messages.
06-21-2018 09:57 PM
Yeah I know the official line but also know the real world experience while away from my home province
06-21-2018 09:52 PM
@ShawnC13 the official rules state if you leave your home province you can only make calls within that province and incoming call will not work. reality however suggests that you can receive calls without the Long distance addons (which is contrary to the official line) the area code does not factor in at all.
When outside your province
- Calls made to whichever province you are in are free
- You wil not receive calls unless you have a long distance add-on
- You will be charged for each minute of incoming call
06-21-2018 09:22 PM
I don't think that if you travel out of your province and only have province wide that calls will not be received from other area codes that are not from the province you are currently located in. (that was a triple negative so I think it got back to being the negative I am not sure I confused myself)
06-21-2018 09:15 PM
@srlawren agreed but that's why when I reply to those questions I like saying both the official and the loophole, so that people know both and can make informed decisions. But also in the end I would always recommend the long-distance addon as it is great value and makes the provincial calling issue void.
06-21-2018 08:52 PM
@mimmo wrote:
@srlawren wrote:
@ShawnC13 wrote:
@TeresaHawkins wrote:With the provincial unlimited talk, do you know what happens if someone from another province calls you?
you can still receive any calls with provincial calling with no issues
...as long as you are physically in your home province.
@srlawren that's the official rule, but unless things have been fixed I believe you will also receive calls while outside your home province,you just will not be able to make them.
@mimmo I'd rather err on the side of what's published, as the loophole could be fixed any day without notice. Let's set expectations accordingly.
06-21-2018 08:48 PM
06-21-2018 08:41 PM
06-21-2018 08:36 PM
06-21-2018 08:31 PM
06-21-2018 08:29 PM
06-21-2018 08:08 PM
Actually, the provincial talk, with intl text is $25.
... Unless there is a promo going on, in which case I want it!
06-21-2018 08:01 PM - edited 06-21-2018 08:42 PM
@TeresaHawkins PM do not offer any text add-ons at this time. The info you got from Walmart is wrong. The cheapest plan with a text option is for $20 $25 (unlimited province-wide talk and global text). If you would like to see more deals on plans, visit the plan page: https://www.publicmobile.ca/en/on/plans
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
