Alternate Phone Number Regex Help
chanrobi
Still getting this error trying to port my number. Tried different computers and different browsers. Would love to get this solved....
imcphers
@chanrobi
Try checking the I am authorized box first.
Then put in account # from Telus
Then put in authorization name
Alternate phone # is another phone # where you can be reached if there is an issue.
Do not put in IMEI and don't put in the PIN - try with just the basic info that I mentioned above.
chanrobi
So i've activated a new line and number, and it works.
I got to my 'plans and add-ons' tab, then go to 'change phone number' (this is all in my incognito page),
I go to transfer number... fill out
alternate phone  (is this the number I am trying to port?)
and
authorization name (name on my telus account bill?)
I check "I am authorized to transfer this phone number"
but it just gives me a red error stating "you must be authorized to transfer this phone number"
.... what do I do?
concordia88
You have to make sure your old account is still active before you make the move.  Otherwise, your port will not be complete.
imcphers
See this post by @imm1304
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-UPDATE-Only-10-days-left-to-get-our...
Give it a try it worked for the other user he was helping!
imm1304
Hi @chanrobi!
Activate a new line with a new number.  Port your number to PM from selfserve once you have the line up and running.
Start in Google Chrome with a new incognito window.
Go to activation page.  If you are not able to select a new number, then selecte a different province for your address and try again.  Also, verify that the first name field does not have more than 11 characters.  These things can be updated later to reflect your correct info from selfserve later.
