01-10-2024
07:11 PM
01-11-2024
07:32 AM
computergeek541
I saw an add-on 15 day US unlimited talk and text by using 10 points. It says MAY take 24 hours to process. Does it mean I have to purchase the plan 24 hours ahead before I can use, not know when it will be effective.
01-13-2024 01:18 PM
Thanks for the advice. The link to the customer service is so helpful. I spent an hour talking to the robot online and didn't get to anywhere.
01-12-2024 11:57 AM
I would wait the 24 hours just to be safe. If my experience public will let you know if there is going to be charge to call the US. When I have bought minutes, the call just goes through
01-10-2024 07:15 PM - edited 01-10-2024 07:15 PM
@williewong Typically any add on starts immediately after it’s purchased . So it’s advised to do so just before you leave on vacation. . I have never used points to buy US roaming so not sure about the 24 hour delay . But you can confirm with support to be certain
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
01-10-2024 07:14 PM
yes, to be safe, you should give yourself 24 hours But many reported they got it almost instantly
and keep in mind, the US addon 15 days "timer" starts when PM successfully loads the addon to your account
