01-08-2025 06:12 PM
I have purchased 3 GB of data and it tells me I am out of, it’s not possible , last time same thing? Do I need a new provider
01-08-2025 07:07 PM
use the app on your mobile device. Soon as you log in you'll see Usage Breakdown > you'll see Add-ons...your purchase will be noted there.
01-08-2025 07:05 PM
where is usage break down
01-08-2025 06:58 PM
@Cate1 wrote:Did I buy the wrong thing
Could very well be...use your cellphone to log in on the PM app, click on Usage Breakdown, then look under Add-ons to see what you bought. If you bought the 3GB / 15 Day US Roaming add-on...that's the wrong one to use in Canada. Message Customer Support and ask to have the purchase amended to the Canada Data add-on. Click the orange bubble on lower right side of page to start the process.
01-08-2025 06:52 PM
01-08-2025 06:50 PM
I bought 3 last night 7 January and 2 on 16 Dec,
01-08-2025 06:47 PM
I bought 2 GB on 15 Dec. I bought 3 GB January 7 , last night and have been told I used 100 % of my data. Simply not possible. IAM not very tech and have trouble with operating my phone but I know I have spent way too much money and not getting what I paid for. All help will be greatly appreciated
01-08-2025 06:19 PM
@hTideGnow wrote:HI @Cate1
when did you buy the 3GB data? are you aware that data has a expiration of 30 days? if the last purchase was over 30 days ago, then it likely got expired and hence got dropped off from My Account
Only 3GB data I can see is 15 Day US Roaming add-on.
01-08-2025 06:14 PM
HI @Cate1
01-08-2025 06:14 PM - edited 01-08-2025 06:16 PM
log in to your mobile account > Usage Breakdown > Add-ons...see if it's noted there.
added...3GB's data for use in USA ? Make sure you have Roaming Data enabled.
