08-20-2021 05:58 PM - edited 01-06-2022 03:12 AM
Hi,
My monthly data have been fully consumed and no longer available for use.
There is also 2.5GB of free add-on DATA available in my account.
I think data should automatically go to add-on data, right?
But now my data cannot be used.
Thanks,
Kim
08-20-2021 06:41 PM - edited 08-20-2021 06:43 PM
@kimwen wrote:reboot phone and don't work.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit HERE
click HERE
or visit HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
08-20-2021 06:38 PM
08-20-2021 06:07 PM
@kimwen wrote:I used all my monthly data, but my add-on data is available for use.
if you see it, then do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
08-20-2021 06:05 PM
@kimwen wrote:Hi,
Thanks,
Kim
If you see the addon listed in your overview, yes, it should be available to use.
Try rebooting your phone, or toggling into airplane mode, then back again.
Then enable Data and see if it works.
08-20-2021 06:03 PM
08-20-2021 05:59 PM
because you used all data..
