09-17-2022 02:51 PM
I bought the US Roaming with data on Sept 11 while on the USA. I got back to Canada on the 14th and I get a message saying that I can't make calls to a number in the USA because I used all my available minutes. What am I supposed to do?
Thanks in advance
09-17-2022 04:16 PM
Thanks to all for your responses. I just wish Public Mobile would specify this fact clearly to avoid confusions.
09-17-2022 03:11 PM
To call a US number whilst you're in Canada, you need this add-on....
09-17-2022 03:06 PM - edited 09-17-2022 03:08 PM
@JorgeMolina Unless you have one of older (now grandfathered) plans with Canada/US calling included, then now you need to purchase the 1000 US minutes ($15) in order to call there from Canada as mentioned.
edit: the good thing about the 1000 US minutes add-on is that it doesn't expire (unlike the roaming), so unused minutes stay with your account until depleted for future use.
09-17-2022 03:05 PM
@JorgeMolina , the roaming add-on you purchased is for use while roaming in the US. While in Canada you need to buy long distance minutes for US.
09-17-2022 02:53 PM
@JorgeMolina wrote:I bought the US Roaming with data on Sept 11 while on the USA. I got back to Canada on the 14th and I get a message saying that I can't make calls to a number in the USA because I used all my available minutes. What am I supposed to do?
You will need to buy a long distance minute add-on. Roaming add-ons cannot be used to make calls from Canada to the US.
