03-04-2019 03:59 PM - edited 01-05-2022 03:35 AM
Hi All,
Heading down to the states for work. Will need data to run an App + check e-mails etc. Does it make sense to get the Add on Talk & Text bundle and then the 1G data separately? Can you do that? Add mutliple add ons for the US?
Thanks!
03-04-2019 04:10 PM
Like Metal1967 said, that would be the way to go(U.S. talk and Text Bundle + U.S. Data Only 1GB).
And yes you can stack add-ons as long as they are different.
Eddy
03-04-2019 04:10 PM
Thanks @Metal1967 & @Lieux !
03-04-2019 04:05 PM - edited 03-04-2019 04:05 PM
Yes you can do that and have them after buying them during 10 days @Noosiekins .
03-04-2019 04:02 PM
Talk and text..then the 1 gb data is a good way to go...
