Add On - US Roaming
rlh
On April 4, 2023 I bought US Roaming Add On for 250Mb for $10 for 15 days. It is now expired. I went to buy another same add-on and it is not listed? Only $20 1GB listed. Is Public trying to raise income by doubling the price of basic service?
dust2dust
It's entirely normal that the same add-on is not available while one is still present. Does it show as 0/15 after clicking the little spinner refresh icon under the Shop Add-ons button?
You can stack all the data add-ons you like. Just not the same one. Either ask support or buy a different one or wait.
What's not "normal" is that there is a wait to begin with.
hairbag1
@rlh
it's best to wait for 24 hours after the first add-on has expired, then you can re-buy the same one. Otherwise you can buy one of the others.
To buy the same roaming add-on again, you will either need to wait 24 hours (Public Mobile system design issue) or you can ask a customer support agent to add it again for you. First, ensrue you have enough available balance to pay for the add-on in your Public Mobile account. After checking for that, please open a ticket using the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
@rlh   PM roaming has a weird rule, after the roaming add-on expired, you have to wait a FULL 24 hours to be the exact same roaming addon
you can certainly buy a different roaming addon or you have to wait 24 hours to be the same
if you want to buy the same but don't want to wait, you will have to open ticket with PM for them to help to buy for you
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
