Refund
Roger10
While roaming in Phoenix I was able to use my phone everywhere except in my Gilbert home.  Even outside my door I could get service.  I called Public, upgraded my Public service on Public's advice, called T-Mobile but unable to resolve.  I think I am due a refund on the amount I paid for roaming I did not receive.  Thanks Roger Ludwick
My assumption was they forced a VoLTE update, but I am just speculating.
dust2dust
It sounds like they erroneously suggested to get a 4G plan. Can you tell if your phone has been enabled for volte? What worked? Did you get one of the bundles or just data?
DennyCrane
Service is never guaranteed in all areas. Your service was working, so I don't think you're entitled to a refund. That said, you can try your luck.
hairbag1
@Roger10
so you were successful at using the roaming add-on in alot of places...just not at your home in Gilbert ?
You can ask, but don't be disappointed if your request for credit is rejected.
@Roger10   so, you did get some service but not everywhere?
You can open ticket with PM support and share your experience, they might compensate accordingly:
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
