06-16-2023 03:07 PM
I’m in the US and have prepaid for time and text add on and it’s not working
06-16-2023 07:45 PM
@GarVin1 cool, yes, you need T-Mobile for the roaming to work (used to be AT&T as well, but no more)
curious, which city you are in?
06-16-2023 07:44 PM
thank you. It finally started working when we were actually in the coverage area for T- Mobile.
06-16-2023 07:43 PM
06-16-2023 03:10 PM - edited 06-16-2023 03:14 PM
@GarVin1 Try to reboot the phone and make sure you’re connected to T mobile . Also is it possible you just purchased text add on and not US roaming add on by accident check like this
simply try refreshing the page to check data plan / mins / add ons
if you purchased wrong one . Ask support to reverse for you
Message support directly
06-16-2023 03:08 PM
@GarVin1 you got Roaming Talk & Text?
Which city and state you are in?
Text should be relatively easy to make it work
But first, do you see your phone connected to T-Mobile network?
if not, try to change the network connection from Automatic to Manual and pick T-Mobile form the list
06-16-2023 03:08 PM
I hope you're not in Alaska. Are you in a more rural area? Or a more urban area?
