08-07-2024
04:29 PM
08-07-2024
04:34 PM
computergeek541
I tried to activate my main number and gave them another number as alternate but they use that number as my main number how do I get my main number back and then port it?
Joining Public
08-07-2024 05:44 PM
I wanted to port my main number but the alternative one ported out it was just if something went wrong but I’m good now all fixed
08-07-2024 05:41 PM
Thank you thank you so I so appreciate it the lady was so helpful I got back my main number Yahoo!!!!
08-07-2024 04:47 PM
After getting back my number porting out public
08-07-2024 04:46 PM
@Mama_bear Are you porting into or out of Public Mobile?
08-07-2024 04:40 PM
hi @Mama_bear
weird situation.
PM porting support team can confirm what number you gave and change for you if need. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
08-07-2024 04:36 PM
@Mama_bear wrote:I tried to activate my main number and gave them another number as alternate but they use that number as my main number how do I get my main number back and then port it? Have you received a text messsage from your old carrier about porting to Public Mobile?
The alternate number shouldn't actually matter. It's not suppsoed to be used for anything other than a number that Public Mobile can contact you if there's a problem with the number port.
