Activation
02-10-2023 02:47 PM
$40 for 15GB promotion is not showed in plan option when tried to activate sim in Step 3
Plans
02-10-2023 04:48 PM
Thanks for everyone help and problem has been resolved with manual fixed by CSAgent .
Besides, I have a referral code from my friend already.
I appreciate your support and time.
Have a great day
02-10-2023 03:27 PM
02-10-2023 03:24 PM
I followed $40/15GB plan screen to activate a sim ,but plan option won't find in Step 3. CSagent to help me
02-10-2023 03:08 PM
@PYMak I can also confirm the $40/15GB and $45/20GB plans are still available in My Account. Make sure to scroll with the arrow to the right side of the plans options to get to the right one.
02-10-2023 03:05 PM
@PYMak wrote:It is still showed on website
https://www.publicmobile.ca/en/on/plans#plans-start
I followed the link up to plan but won't see the option
@PYMak one more thing, the Plan show on the link there is not updated. There are more plans to choose from when you actually go to activate. And yes, $40-15GB is there.
02-10-2023 02:54 PM
@PYMak it is still there, the screenshot I showed was the one I just did
try again using Incognito mode, or another browser
or try on a desktop computer. key is, make sure 4G speed plan is there. If you are using a mobile, make sure you scroll down and look through all the plans
02-10-2023 02:53 PM
02-10-2023 02:53 PM
@PYMak Also if you don’t have a referral code for step 4 to save $10 I’ll send your a referral code also
02-10-2023 02:52 PM
02-10-2023 02:50 PM
@PYMak It’s there you have to use the arrows to keep cycling through them
02-10-2023 02:50 PM - edited 02-10-2023 02:51 PM
02-10-2023 02:50 PM
@PYMak it is there,
make sure you are in the 4G plan tab
YOu might want to try again using Incognito mode
