01-27-2022 08:26 AM
Hello.
I tried to activate my sim card and followed all steps. When I clicked final step to activate sim card I got 2 check marks really fast but when it got to plans it was just froze then an error screen popped up. I tried to go back and go through activation again but now says I have an invalid sim card number.
Joining Public
01-27-2022 09:30 AM
If you tried to activate few times and failed do not be surprised if your card is charged multiple times.
01-27-2022 09:21 AM
I since got the text and all is good. Thank you
01-27-2022 09:00 AM - edited 01-27-2022 09:02 AM
@Mk555 First put in your PM SIM card and confirm if you can connect to the PM network and make outgoing calls. If so, good, you account was activated
next thing you can do is to confirm the porting status. I will private message you a phone number to call. Check your Community inbox, envelope icon on top right. they can provide you update to your porting request
However, if putting your PM SIM and the phone cannot connect to the PM network and you cannot make an outgoing calls. Come back and tell us what the screen showing for the issue (like if it says "SIM not provisioned", "No Network", "No SIM", etc)
01-27-2022 08:59 AM
How long ago did you activate? It might take 1-2 hours to receive that text.
Try the PM SIM card in your phone. See whether you are able to call or text out.
Do not activate again or your will be charged again.
01-27-2022 08:55 AM
I was charged but I did not receive the text message from my old provider to allow to port my number over to public
01-27-2022 08:34 AM
First check if your credit card was charged. If charged, try your PIM SIM card in your phone.
If not charged, you can try again in one hour. Or you can clear cache, incognito mode or a different web browser. The activation system can be finicky at times.
