Activation
Mabolla
Hi,I just activated my sim card and got a plan, I can make calls and use Internet but I am not able to receive calls, whats the problem
11 REPLIES 11
@Mabolla wrote:
Yes, I port a number over, how can I reset my network setting?
@Mabolla
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
and if still not fix it please you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Only one way to solve your issue , explanation to Customer Support Agent by CS_Agent,
and the are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here to get started.
  • or you can send a private message to Customer Service by CS_Agent, by Click Here
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck
@Mabolla
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you missed approving the port from your previous provider, insert the old SIM and see this:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
@softech
LoL good analogy! Should also get a good lawyer too to get the most out of your ex.
Good thing I haven’t gone threw it.
withkarma
Hey @Mabolla
I've had similar problem before when I joined PM. From my experience, the settling in is not instant. It took me a few days, like 3 days till it actually worked. Think of it like a foundation of a house. It needs time to settle-in before its safe to actually to call it your own. Same idea here.
Hope this guidance and the support of others helped.
Tm
@BKNS27 wrote:
@Mabolla
I hope you didn’t throw the old SIM away.
Many ppl do that..  they hate their past so much and don't want to see it ever . .kinda like a divorce. LoL
@Mabolla
This is a common mistake by most new PM members porting over…missed the instructions on how to port over your old number.
You will need to contact a PM CSAgent to restart the porting process for you if you missed the 90 minute window or you didn’t reply to the text.
Click on the SIMon chat button and type in create a ticket to restart the port.
@Mabolla
Did you reply YES to the PAT (porting authorization text)? If not you must reply within 90 minutes of recieving it. Try putting your old sim card in and replying YES and see if you can still make the 90 minute window. Otherwise keep your old sim card in for now and reinitiate your port request in the morning  by contacting customer support or calling the telus porting department with your old account #.
@Mabolla
If you ported your old number over, you need to reply to the SMS text from your previous carrier with YES with your old SIM in the phone.
But if you are choosing a new number and not porting, just power off the phone and wait a few minutes then power it back on as noted by @JK8.
You also might want to see if the Do Not Disturb setting is turned on…just turn it off if it is.
@Mabolla   did you port your number from another provider?  If so, did you receive an SMS from your old provider and did you reply YES within 90 min?
if you have completed above and completed not too long, it should work after couple more reboots, another hour or so.
However, if you have missed the SMS or you didn't reply, you will need to contact Porting team to re-trigger the process.  This is a critical step in porting.  I will send you the phone number via Community inbox..  Check ..
Mabolla
JK8
Did you port a number over? Try resetting network settings and reboot.
