08-21-2019 03:39 PM - edited 01-05-2022 08:38 AM
I want to switch my boyfriend's phone today but he has it til after 11:59 est. I have a dual SIM phone can I switch it with my second SIM card slot and then just give him that SIM card when he gets home?
08-21-2019 07:04 PM
A good option but using the dual SIM is just slightly easier for me. Thx for the advice
08-21-2019 07:03 PM
Thx that's perfect a little easier than getting a temp number but both solutions work especially if you don't have a dual SIM phone. Thx
08-21-2019 05:17 PM
identifcal threads have been merged
08-21-2019 04:11 PM
@darlicious you can activate the Sim card now and pick a temporary number for now and port his over Tonight or tomorrow. Is that what you meant?
08-21-2019 03:55 PM
.@darlicious Yes you sure can. It does not matter what phone the sim goes in or slot it can be taken out and put in a different phone anytime.
So using your 2nd sim slot is perfectly fine
08-21-2019 03:51 PM
