How does it work?
waternlava
So, just to confirm, add-ons are carried over to the next month until completly used up but in-plan minutes and data disapear and renew every 30 days. Or are they carried over as well?
If someone could clarify things that would be great.
Thanks,
Daniel
Plan provisions (minutes, texts, data) renew each time you pre-pay the next 30 days of service. Unused minutes, texts, or data are lost.
Add-on provisions (minutes, data) remain attached to the account until they are fully consumed or the account is finally terminated. Partially used Add-ons keep carrying forward. Fully used Add-ons drop off the list. You can always logon to your Self-Serve to see what you've got left.
Plan provisions are always used first, Add-on provisions are only used when no Plan provisions are available. You don't have to buy Add-ons and you don't have to pay for them each month (unless, of course, you keep using them up).
The only exception is US Roaming Add-ons. Purchasing and activation is a two-step process, but they become active immediately and they expire after ten days - whether you use the or not - they can't be paused/suspended/resumed, there's some restrictions for how multiple US Roaming Add-ons can be combined, and they can't be stockpiled in advance.
Dunkgirl
Thanks,
Daniel
@waternlavaYes you have it correct. Purchased / Bonus add-ons are good till used  except in the case of timed add-ons that explicitly say so. Such as 10 day us roaming.
iliusfaisal
Holidays add-ons do not have any expiry date. It will be in your account till those are used up
