Activation trouble
BazSr
I tried to port my number, got a message unable to complete activation, get support. Support says I had to chose a new number because I was coming from Koodo. Now I can’t get back to change my option. How do I fix this? It already took payment!!!
hi @BazSr you opened a ticket?  go to the inbox here and look for the message
@BazSr
Good. You will need to contact a CS_Agent on the Chat bubble and type in Submit a Ticket or Contact Agent.
Or you can pm them at:
Agents will reply back through pm so click on your avatar (top right) the Messages.
BazSr
How do I reply support? What do you mean?
BazSr
Yes
@BazSr
Did you activate/port on the PM app? You can only do it on the app.
hi @BazSr  you have Koodo Prepaid service?
Please reply support  ,  tell them you are unable to login and do what they suggested.  Ask them to give you a random number first
