11-25-2022 10:21 PM
Everything works fine, expect sms can't receive any of them.
I transferred my phone number from Lucky , I'm not sure it got transferred successfull.
11-25-2022 10:37 PM - edited 11-25-2022 10:38 PM
Reply to the text with YES now!
Hopefully, the porting will be completed.
My friend did the same mistake and replied 4 hours later (outside the 90 minute window).
He got a reply back from a CS_Agent the next morning on the envelope icon above and got him off running on his phone.
11-25-2022 10:33 PM
@cadieuxal007 wrote:That's the issue I just saw the sms from Lucky , I had 90 minutes to reply. Oups what to do ?
@cadieuxal007 still try to reply yes. now
Reboot your phone couple time tonight to see if you are getting incoming calls
If not , call Porting team tomorrow and they can re-trigger the process
11-25-2022 10:33 PM
Thanks
11-25-2022 10:32 PM
11-25-2022 10:32 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. The porting support is closed for the night, Call them tomorrow morning and get it fixed
11-25-2022 10:30 PM
I can call out but not receive calls also
11-25-2022 10:28 PM - edited 11-25-2022 10:29 PM
If you replied to the text from Lucky confirming you are porting your number to PM.
The next step is to Power Off (not turn off the screen or restart) your phone then swap the Lucky SIM with the PM SIM then power the phone back on.
You probably check already to see if SMS is enabled in your Settings.
11-25-2022 10:27 PM
@cadieuxal007 can you receive incoming calls? Try to call from landline
if you are receiving incoming calls, then you should receive text from friends. The ONLY text you cannot receive might be those 2FA text from Banks? if that is the case, it is normal. System generated text like 2FA text usually will delay for couple days. You should start getting those text within 3 to 7 days
