Activation failed
JonahL
I'm trying to switch to PM from Koodo. Using the mobile app, I was at step 6 of 6: Activate. At this point it says Subscription not activated, something didn't go right blah blah.
What do I need to do to get this fixed? Thanks in advance!
2 REPLIES 2
JonahL
Hi thanks for the response. This is for esim. Thanks for the steps, I was having trouble getting through the chatbot to submit a real ticket. 🙂
HI @JonahL physical or esim?
but check with support agent.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
