03-07-2024 11:47 AM
The promotion $34 plan i subscribed is supposed to be 5G but is running on 3G speed, need help
03-07-2024 11:50 AM
HI @Sam_kw
what phone do you have? model?
did you check the network mode on your phone? is it on Automatic? try that first, if not working, try changing to 4G/LTE first and then try 5G (or 5G ON)
If speed is still not good, can you run a speed test and tell us how bad it is ?
