09-25-2019 06:22 PM - edited 01-05-2022 07:16 AM
I am trying to activate a new plan/sim card. I am on step #2, phone number. When I put in an alternative phone number in case they need to contact me, it doesn't work! It just keeps saying this, "Alternate Phone Number Regex Help" and it won't let me proceed on to the next step! Help!!?
Thank you!
09-26-2019 07:21 PM - edited 09-26-2019 07:32 PM
I believe where you have :"Select Your Group" in the DROP DOWN MENU - is Supposed to be to Select Your Area- That's what I recall (in N.S.)
then you choose (Double Click) a number on the List; or
TRY TO CREATE YOUR OWN, but it's NOT EASY
09-26-2019 07:17 PM
My Friend just Created an Account a few hours ago.
I'm Pretty Sure the Alternative # is NOT Required.
Perhaps the Red Asterix was to Correct Information, Maybe any Dashed in the Number?
09-25-2019 06:47 PM
Then select Transfer Number:
09-25-2019 06:43 PM
Click Plans and Addons, then Change Phone Number.
09-25-2019 06:41 PM
Site seems very slow now. It's in My Account. If I can get there, I'll post a screen shot. Are you using phone or laptop?
09-25-2019 06:40 PM
@heidib1 wrote:Thank you very much, I had to do this. I sure hope I figure out how to import my number afterwards!
Generally, a good idea to activate new plan with a temporary new number. Try the service and if you like it, you can port your number over via your self service account. Not too difficult to do.
Just choose Change your phone number option in self service account. Three important pieces of information that you need to port: Account number, account holder name and phone number to be ported.
09-25-2019 06:37 PM
09-25-2019 06:31 PM
Incognito mode. Click on the three dots if on phone in the top right.
09-25-2019 06:29 PM
If you are porting a number you might want to consider taking a new number to start and then when everything is working you can port in the number.
09-25-2019 06:29 PM
I don't know what incognito mode is!! Please let me know! No, not using brackets or dashes.
09-25-2019 06:26 PM
Thank you, I will try in chrome. But it has an asterisk beside the alternate number meaning I must provide one for when I activate this account.
09-25-2019 06:25 PM
Are you trying to use brackets or dashes?
09-25-2019 06:25 PM
Can you try in incognito mode
You may have to wait for sim to be released from a session
09-25-2019 06:25 PM
Website can be finicky. Can try clearing cache, different web browser or incognito mode. Chrome incognito seems to work well with this site.
Technically speaking, you don't need an alternative number. With one of my accounts, I don't have an alternative number registered. It is nice to have one just in case there are porting issues though.
