Activating a new plan without a credit card or debit card
RajanC
I'm trying to activate a new account and plan (90 days 20gb 4g plan @ $34/month), but ran into payment issues. Found out public mobile doesn't accept international credit cards. Is it possible maybe to purchase a $115 voucher to be used to activate the service with? Also need to port in my number as well. Thanks
That is now true for sign up. It seems to be forced by the postal code filter only allowing Canadian postal codes.
I'm not sure the reply earlier about a temporary set up and then add money with vouchers is true. It was for a while, a while ago.
Then after sign up you can put in a US card. The gift card idea I think is best.
RajanC
I just got this reply from cs. Has their policy changed?
Hi RajanC,
Thank you for contacting The Public Mobile Team. My name is Mary, and I'm happy to assist you today.
I'm sorry to hear that you are having issues with the activation. Since we work with subscriptions now. The only way to activate a Public Mobile account is by using a credit card issued by a Canadian financial institution and associated with a Canadian address.
If any other concern arises, We are here at your disposal.
Regards,
Mary
Customer Support Agent
RajanC
this is a really good suggestion will try it out. Thanks
wetcoaster
You probably have sorted this out by now, but...
As an alternative to the process above, these prepaid credit cards also come in higher denominations and can be used for activation. You want the available amount on the card equal / higher than the plan cost your signing up for, but after you have activated you can use the remainder on the card for grocery shopping etc. The one I have on file is empty and I just make sure that I'm loading vouchers before renewal.
There are also reloadable credit cards like Canada Post's  or KOHO , as example.
Also... Not sure where you are coming from with $115 vouchers for the $102 plan.
* Tax is paid at the point of sale, so you would pay the retailer the voucher value plus tax and load the vouchers to available funds.
* If there's enough in available funds to cover plan cost the system will just take the plan cost, no tax. So, if you go through CSA sign-up as outlined above, I'd just buy $105 (I have not found smaller than $5 increments for "normal" vouchers, I don't have experience with "direct deposit vouchers" / real time top ups). At my local London Drugs I'd get two $40 and one $25 vouchers.
* If it's a mixed payment, ie available funds only cover part of the plan but the rest is charged to the credit card on file, only the amount charge to card will be taxed, which will show accordingly on the card statement.
Yummy
- Get SIM
- Ask agent to open account for you and immediately suspend it
- Buy a voucher
- Pay with voucher
snowisfalling
 Yes, you can activate with voucher, just a bit more steps:
  1. Open ticket with PM support by direct message them:
  2. PM support reply and ask you for the sim card number, an email address used for the activation (login for My Account).
    They will activate the account with the sim card.  The account will have status SUSPENDED.
    PM Support will then sent you the login and password.
  3. Once the account is setup, you can login to My Account and load your voucher to finally activate the service.
