Switching back to original plan
Clooch27
I would like to know if I change my plan, from a 3G to a 5G plan, if after a month or so, I can change it back to the plan I had originally. In case I don't find it worth the money or any other reason.
Thank you
Clooch27
Thank you.
KennethJAdams
Hi @Clooch27
To add on to what the others have said, please share with us what plan you have. Another idea is if you want to try the plan and then say... naaaa...  then go back....  why not just open up a whole new plan and try it out. Sure yes, you're paying both amounts but... like I said... we're not sure what plan you have so...  let us know so we can help you decide. 🙂
hI @Clooch27
yes, you can always change plans back and forth, but as long as the plan still available.  And, the $15 and $25 will probably  be here for now, but other plan could change.  PM has came up with many new plans lately
And remember to use Change on Renewal instead of Change now to schedule plan change
