Account
Putteyhead
How do i gety account number. Cant login
@Putteyhead account number  is 8n the profile page after you logged into My Account.   What exact error you got when you login?
Try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@Putteyhead
There is a cache issue with the website so clear The cache, cookie and go incognito on a laptop or desktop.
Have the 2 FA code sent by text then go to Profile and move cursor over the hidden account number.
@Putteyhead  Try again incognito mode private mode or another device or laptop then go to profile tab for your account number
