02-25-2022 10:49 AM
I have been trying to get in my account and I can't sign in
My Account
02-25-2022 11:06 AM
@ZenA wrote:I have the correct email but I forgot my security answer therefore I can't reset my password
Yes, go ahead to open ticket as advised above. PM Support usually will reply back within an hour or two. But check the Community inbox here for their reply
02-25-2022 11:03 AM
02-25-2022 10:50 AM - edited 02-25-2022 10:52 AM
You tried Forgot password link (https://selfserve.publicmobile.ca/forgot-password/) and try to enter all the possible email addresses you have and see which one works? Once you entered the correct email address, you will be asked to answer the security question
If still fails that way to reset password that way, please open ticket with PM Support and they will sort that out for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
***Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
