Account trouble
jamiearis
Good day
I have 2 phone numbers for kids and would like to  know if its possible to see both "accounts" in the same spot.  The portal won't let me use the same email address to register for both, error that the email is already in use.
Thanks
J
popping
@jamiearis wrote:
Good day
Thanks
J
PM does not allow 2 phone numbers is an account.
PM use email address as the username to login to self-serve portal.
As other already said that your can use email alias.
If you email address is [email protected]
You can have [email protected] for your daughter account and
[email protected] for your son account.
All emails for these 3 aliases will be delivered to [email protected].
But alias will not eliminate the issue of one login to view both child's account.
But in order to view daughter's account, you need to login using [email protected].
gpixel
@jamiearis you can use an email alias
ie. [email protected]
[email protected]
RosieR
@jamiearis wrote:
Good day
Thanks
J
Hi @jamiearis sorry you cannot put two accounts together.  One sim card and one unique email address.  You can enter your credit card number for both account for auto pay.
JoyLuck
@jamiearis wrote:
Good day
Thanks
J
Each phone number must have a separate account (email address). If you use gmail create an alias.
