02-20-2023 03:31 PM
I am getting a message saying my account is suspended and I need to make a payment but I have auto pay set up and that has been working fine the past several months. Nothing has changed on my end so why wont Public Mobile take the payment. There are plenty of funds available in the account and the card in question is active and has no issues.
02-21-2023 01:19 PM
Tried both. same issue persists.
02-21-2023 01:18 PM
My service is down and I have auto pay active and that has been working with this card with no issue for the past several months. I have also tried other cards and it still isn't working.
02-21-2023 01:17 PM
Service is not functional which is a major issue as I need my phone for work. I have tried adding funds with multiple cards and consistently get the same "oops..." error message.
02-21-2023 01:15 PM
All the card info is up to date and correct and the card is valid and has funds available. I have tried multiple cards with the same "oops..." error result. I have also tried in multiple browsers and with incognito mode on.
02-20-2023 03:53 PM
Make sure that your credit card info is updated - check the expiry date.
02-20-2023 03:43 PM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you still have service and your plan renews today / tomorrow you can ignore this suspended notice
02-20-2023 03:40 PM
@robinokane , is your service functional at the moment? If not, login to your self serve account using incognito mode to confirm account status. If the account is in suspended status, simply do a manual top up and reactivate.
02-20-2023 03:38 PM - edited 02-20-2023 03:39 PM
If your renewal date is tomorrow. This is normal. You should still have service so ignore the suspended notice.
But if you don’t have service, login to your account and check to see if AutoPay button is enabled in the Payment section. Turn it back on if it is disabled and refresh your browser page.
02-20-2023 03:33 PM
Try refreshing the page or using incognito to access your account info.
