03-10-2023 04:31 PM
03-10-2023 05:12 PM
@ipaata1 wrote:I need to contact real person from customer service to find out account number
@ipaata1 wrote:
I don't have chance to accsess account
PM does not have call centre which you can call. PM support is provided by this community forum and is a members helping members model. If your issue requires access to your account, you need to create a support ticket. A CS Agent will contact you to solve your account issue. A CSAgent is a PM employee who is real person you are looking for.
If you activate your PM account online, a self-serve account was created for you at the end of the activation process. Use your email address, provided by you during activation, as the username and the password, provided by you during activation.
Ask if you have more question. Members here will be happy to help you.
03-10-2023 04:42 PM - edited 03-10-2023 04:43 PM
@ipaata1 wrote:I don't have chance to accsess account
@ipaata1 if you have access to My Account, this is the quickest way, unless you forgot the login
Are you trying to port out the phone number, if the choice is there one the new provider, you can try to enter IMEI number instead of account number
If account number is really needed, and you don't have My Account access, open ticket with support to get the access back
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
03-10-2023 04:40 PM
PM is all done online so no live person to talk to. Not really that hard to do.
If you can’t login to your account due to login ID or password are incorrect.
You need to contact a CS_Agent to help you access your account to get the account number.
03-10-2023 04:40 PM
Why not? Need 2FA for the email box? Don't have an active account for the SMS option for both?
03-10-2023 04:37 PM
03-10-2023 04:36 PM
03-10-2023 04:34 PM
@ipaata1 There is a chance you can find the account number from the Welcome email, if you can find it
if not, login to My Account, profile page and it is there
03-10-2023 04:32 PM
Log in to your account and look in the Profile section.
