Account number
mjoneson
Where do I find my account number?
Dublicate_acct
As others mentioned ----
Log in to your account ----- then click on profile -------- there you will find your account number and more --it will even show your SIM card number --- good luck.
HI @mjoneson
Check My Account for your acocunt number
if you cannot login My Account, you might be able to get it from the Welcome email,
@mjoneson
login to My Account, go to Profile page, the account number is there
https://myaccount.publicmobile.ca/en/account/my-profilehttps://myaccount.publicmobile.ca/en/account/my-profile
@mjoneson  In your my account on the profile page . Or if you can’t log in and just need it to port number you can ask support to retrieve it for you
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
dust2dust
Can you log in to your account? If so then it's in the profile area. Do you still have the welcome email from when you signed up? It might be embedded in the headers or source.
