11-16-2022 07:53 AM
I have two (2) phones on my account and when I login to Public Mobile - My Account I only see one. How do I get to see both phones
11-16-2022 09:53 AM
You cannot have two or more phones (different phone numbers, plans) on your account.
Each account -- phone number - is independent and tied up with unique email. You can pay for multiple accounts with One credit card, though.
11-16-2022 08:40 AM
If during activation the system accidently allowed you to activate two accounts using the same email address one account will prevent the other account from being accessed as only one password can be used to log into an email address/username. You will need to contact customer support to add a different email address to the inaccessible account and reset it with its own password.
11-16-2022 08:14 AM
@bhegge wrote:I only have had one login up to now. When did it change.
@bhegge since beginning of PM , it is always one line one account (email)
There could be a chance your second line never have a My Account setup if you activated in store. In store activation usually do not help you with My Account setup
But either way, open ticket with PM Support and they can sort it out your 2nd line for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-16-2022 07:58 AM
11-16-2022 07:54 AM - edited 11-16-2022 07:55 AM
Every account is separate with a different login and email address. You will not see 2 lines on one account.
