02-27-2023 01:42 PM
I recently moved and my automated payment didn't go through. Now my account is deactivated. I cannot reactivate my account without changing my address in profile and I cannot change my address in profile without reactivating my account (the option is greyed out).
I updated the postal code of my registered payment method but it doesn't seem to be enough, the payment still doesn't go through. It seems that I need to update my billing address in my profile but as I said that option is greyed out.
There's no problem with my credit card as I made the change of address there and have been using it successfully for other payments since.
Any help appreciated,
02-27-2023 02:10 PM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you still have service and your plan renews today / tomorrow you can ignore this suspended notice
02-27-2023 01:58 PM
The payment won't go through on its own. You need to make a manual payment to reactivate services. Then next renewal it will (hopefully) go through automatically (if you kept the toggle on).
02-27-2023 01:47 PM - edited 02-27-2023 01:48 PM
@tresor You don't need to reactivate to change the address to make a payment. The Profile address is just for record keeping
However, if your credit card has postal code changed, you will need to update your credit card info to match
Login to My Account, then go to Payment page, Manage payment method and Update card information and update the postal code
https://selfserve.publicmobile.ca/en/account/payment/manage-card
Once successfully updated the credit card , then try to make a payment by click Reactivate my plan
